How to deal with blush
Well, I should have known it was too humid to spray finish coat lacquer on today and now I have some blush to take care of. It's on the final step after I toned the "cheap" wood with Mohawk toner to darken it. What do you say I should do now? I don't want to have to sand and then retone several small areas including the grille bars on my Philco 38-1 console.
First of all wait for a day and see if it goes away.
Sounds good to me. I'm in no special hurry.... I've had to wait to get started on this cabinet since mid-February!!!
Mohawk No Blush Plus will make that blushing disappear like magic.
[Image: http://woodfinisherssource.com/cart/imag...3-0475.jpg]
Great to have if you spray any lacquer anytime the weather is humid.
Going over it lightly with 0000 steel wool will remove it.
In NC I encounter this often.
There are currently 9009 online users. [Complete List]
» 1 Member(s) | 9008 Guest(s)
