Three radios for 30 bucks
Wa2ise...I'm way ahead of you. Started on the cabinet this morning...we just had our 38th anniversary so I have learned a few "survival" skills over the years.Icon_lol
First you give your woman a diamond ring...next thing you know she will be askiong you for old radios.....you have to know where to draw the line!!!! Icon_lol
If half the tubes in those sets test OK you got 30 bucks worth.
Tube count is 9, so it's a 14 mx.
We Have the same set!! Kewl
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2438 online users. [Complete List]
» 4 Member(s) | 2434 Guest(s)
AvatarAvatarAvatarAvatar
