philco baby grand
hey guys what would a philco model 20 baby grand cabinet in good solid condition be worth david
Is it the standard (early) version or the later deluxe version with the birdeye maple trim on the front? Also in what condition is this cabinet?
Philco 20s are a fairly common set, especially the early version, so the cabinets aren't worth as much as they would be for some other models.
P.S This is technically in the wrong section.
Moved to Philco Home Radios since the OP is asking about the value of a cabinet, not how to repair/refinish a cabinet.
David, could you include some photos?
I could use one.
Philco 91 Tuning Condenser
There are currently 9361 online users. [Complete List]
» 1 Member(s) | 9360 Guest(s)
