Philco Model 48 - 1256
I received this model for Christmas and I don't have the proper speaker for it. Does anyone know what type of speaker I should put into it?
Matt
Looks like there is one available at Vintage Electronics, http://www.king-cart.com/cgi-bin/cart.cg...=&password=
Put 48-1256 into the search box and up comes: Philco 48-1256 SPEAKER p/n 36-1613
(I'm not associated with Vintage Electronics)
Philco 91 Tuning Condenser
There are currently 9320 online users. [Complete List]
» 1 Member(s) | 9319 Guest(s)
