Mod. 50-524 chassis
Are the chassis's the same for the 50-522 & 50-524.Thanks-Jim
Beitman and Sams both use the same schematic for the 50-522 and 50-524.
If you e-mail me, I could send you a copy of the Beitman schematic.
Carl
Northern Panhandle, WV
