Philco Model 37-61 Owners Manual
Here is the owners manual that came with my Philco Model 37-61 F Console Radio. I thought others might want a copy of this manual.
[Image: http://i131.photobucket.com/albums/p294/...Page01.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page02.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page03.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page04.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page05.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page06.jpg]
Thank you for providing this scan for the 37-61 owners manual.
Owners Manuals are scarcer than hen's teeth an usually one of the first
thing lost or tosssed over time.
Chuck
You're welcome. I bought the radio at a flea market and it amazingly still had the owners manual with it. I know there is someone out there who would like to have a copy too so that is why I posted it.
Thanks A bunch, I've been looking for this !!
Rich...
does anyone still have this manual? i just got one and i am going to restore it. i would like the manual for it.. any help would be appreciated.
Gary
Email Chuck Schwark who posted above. (use the EMAIL button on his post) Its likely he retained a copy. He can also send you all the schematic and servicing information in high quality so its very readable for a very modest charge.
Philco 91 Tuning Condenser
