Zenith R-5-312
Hi:
What would you use clean the dial face of this radio (with something that is around the house)? It is very dirty andI dont want the printing to come off.
Thanks, Buzz
Is it painted metal? Windex works nice.
it is painted metal. plastic dial cover was missing and has some paint flicks on it from someone painting room.
thanks, buzz
It its' the kind I'm thinking of with white lettering on a black background Windex or soap and water is fine, if it's on foil test a small spot on the outside corner where it can't be seen.
There are currently 9774 online users. [Complete List]
» 3 Member(s) | 9771 Guest(s)
