need a wiring diagram for a 37-630 chassis
does anybody happen to have, or know where i can obtain a copy of the wiring diagram for a 37-630 chassis. thanks!
A schematic is in Riders volume 7 and page 57. The 37-630 is missing from the Nostalgiaair database.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Tom Bavis has a 37-630 schematic available on <a href="http://www.audiophool.cjb.net/Philco.html">his website</a>. However, please note it is in DJVU format and requires either IrFanView or a DJVU reader.
And you can purchase copies of original Philco service bulletins, with pertinent changes data, from Chuck Schwark:
http://www.philcorepairbench.com/schematics.htm
You can also find info on this page:
http://oldtech.net/Philco.html
Carl
Northern Panhandle, WV
Go to the Website called Nostalgia Air. There is a free schematic service there under the link for resources. Print them for free.
Eico 232 VTVM Schematic
There are currently 6482 online users. [Complete List]
» 1 Member(s) | 6481 Guest(s)
