Is this a Philco?
I gave up trying to find it in the database. It sure is beautiful.
sure is a nice looking Icon_thumbup
Any info on the back or chassis ?
She looks quite tall! What does she measure?
I'm waiting to hear back from the owner. This is the only pic. They say the finish is untouched original and that it's a Philco.
Looks like a Majestic to me. It is not a Philco.
It's either a Canadian Made Rogers set or a Majestic (Canadian or American). The cabinet has also been stripped at some point and/or received a mediocre refinish.
There are currently 9773 online users. [Complete List]
» 3 Member(s) | 9770 Guest(s)
