Philco 90 console
Picked up a 90 console today off of CL
A little moisture damage on the feet but appears unmolested.
Nice findIcon_thumbup!! Looks like a first series chassis with the local/distance switch on the back. Good luck with it!
Kevin
Looks like another good find. You guys are causing me to kick my searching up a notch.
That is a great find, Tim! Yep, it's an early model with the PP-45s and the local/distance switch!!
Icon_thumbupIcon_clapIcon_wave
Way to go! Nice find!
Gene
Thanks, I almost gave-up on getting a reply from the CL seller.
I guess his Spam blocker was working overtime!
Tim, a very nice find and one of my favorites. I had a latter chassis and recently gifted the radio off to a friend for a house warming. Just need to make room for another console. Great radio.
Jerry
Philco 91 Tuning Condenser
There are currently 10140 online users. [Complete List]
» 2 Member(s) | 10138 Guest(s)
