Two Additions-One American One German
Been working on the cabinet restoration of my 40-155. Took a break yesterday and came across a listing on craigslist for two old radios. Upon investigation of the two radios I ended up with a Grundig 5060A and a Firestone S-7403-9 for $70. The Grundig looks like a great radio. Well it's time to get back to work on the 40-155 cabinet while the rain holds off in the Pacific Northwest. Then on to the 370 cabinet if the dry run continues.
Very nice score, seems the NW is becoming alive with radios for sale.
Jerry
Both very sharp!Good job.
There are currently 9813 online users. [Complete List]
» 3 Member(s) | 9810 Guest(s)
