7B5 Loctal Tube
Hopefully this is not a stupid question, but I have a chassis with a few of these 7B5 tubes and one of them has a 2 pins that appear to be missing, are they all supposed to be on this tube?
David, Pins 4 & 5 are not used on this tube:
http://www.nj7p.org/Common/Tube/SQL/Tube...p?Type=7b5
Carl
Northern Panhandle, WV
There are currently 11413 online users. [Complete List]
» 2 Member(s) | 11411 Guest(s)
