Model 660 versus 116B
In looking at the schematic of a model 660 and comparing the tube line-up to a model 116B it appears they are the same except for cabinet and speaker size. Am I right?
Thanks in advance.
No, the 660 is a 10-tube set and the 116 is an 11 tube set.
Also, the 116 has 5 bands and the 660 has four.
The 116B also has a separate #77 pentode 1st audio amplifier and uses a 37 as a 2nd detector rather then a type 75 triode double diode as 1st audio amplifier 2nd detector.
OK guys, thanks for the additional information comparing the two. The extra shortwave bands would make tuning a little easier. It does appear that the two models do have the same IF circuitry, so selectivity would probably not be an issue.
Philco 91 Tuning Condenser
There are currently 6933 online users. [Complete List]
» 2 Member(s) | 6931 Guest(s)
