Philco 48-382
My friend emailed me about my fixing his radio. I can't find it in the gallery.
Bet it's a 48-482 it's an AM/FM job.
Terry is right, as there is no such thing as a 48-382.
Hmmm.....he even checked the # twice.....also mentioned SW.....I'll see
He just sent me the pic......it's a 48-482
There are currently 9706 online users. [Complete List]
» 1 Member(s) | 9705 Guest(s)
