[attachment=2752][attachment=2751][attachment=2753][attachment=2751]I posted this when it was for sale hoping someone else would rescue it. I ended up getting it.
Came with instructions and tag. Nice looking original finish.
Nice to get something that doesn't need refinishing..
Good rescue and score! Especially getting the instructions and tag with it! Icon_thumbup
Ditto, great score! Icon_clap Icon_thumbup
I love that cabinet style!!!!
Icon_thumbupIcon_clapIcon_waveIcon_biggrin
very nice find Tom
Very nice looking radio. Good to see the echo board "think thats what they're called"on back is there and in good condition.
Thanks guys, can't wait to clean it up and get into the chassis.
Saving up the "no need to strip/refinish" projects for winter.
Someday I will have a heated workshop I can strip/spray in..
Tim
Philco 91 Tuning Condenser
There are currently 10220 online users. [Complete List]
» 2 Member(s) | 10218 Guest(s)
