Correct Knob for Philco 91
What is the correct knob for the on/off switch for a Philco 91? My 91 has the same rosette knob that is on the volume and tone controls but I have seen photos on-line of other model 91s that have a smaller rosette type knob.
Late production 91 sets used the medium rosette on the off-on switch as well as the volume and tone controls. The 91 I currently have came with three medium rosettes and a large rosette for tuning.
Eico 232 VTVM Schematic
There are currently 8912 online users. [Complete List]
» 2 Member(s) | 8910 Guest(s)
