The Big & The Small Of It--2 More Found Today
Here are 2 more flea market finds from today. Price was right so of course I couldn't resist! One little Emerson and one big RCA. The RCA is an 8-RF-13 with "Magic Eye" tuning. Now for some rearranging to make space.
Craig R.
Later model Hi Fi RCA models with an Eye, are very cool.....Radio hanging in there till the end.
paul
Great finds! That RCA looks HUGE!! Either that or you have really tiny car.
Gene
No mistaken, it is a HUGE radio (28-1/2" wide x 19" tall). It is designed to rest on a special stand. Chassis is not that big but there are 3 speakers, the outer 2 being angled towards the corners. This is a 13 tube unit with supposedly very good sound.
Craig R.
There are currently 3275 online users. [Complete List]
» 2 Member(s) | 3273 Guest(s)
