cool iphone case
Hi guys,
I thought you might get a kick out of my new iPhone case. It came from a company called Café Press.
I am in no way connected to them other than being a customer. I just thought you'd like to see it.
Eric
The Villages, FL
Icon_thumbup
That is pretty cool!
Icon_thumbupIcon_thumbupIcon_thumbup
Super Deluxe.
You will always have your Philco handy.
WOW...that is really sweet!
-Greg
Just put this app on it and you are all set for some old radio shows to go with the old Philco.
https://itunes.apple.com/us/app/dumb.com...d567195102
Thanks Bob. I just put it in my phone.
Eric
The Villages, FL
Don't you wish Philco was still in the USA and they really did produce I-Phones? How different this world could be..
Philco 91 Tuning Condenser
There are currently 10177 online users. [Complete List]
» 2 Member(s) | 10175 Guest(s)
