38-62 Schematic
Anyone have one or know where I can get it. None online available that i can find.
The set of beitmans that I have looks like 9-19 or 9-18, 8-19, 8-18
I have been to all for no bolo.
Help
Thx in advance
Bradley Rush
There doesn't seem to be a 38-62 on Nostalgia Air, but they do have a 37-62. From the descriptions in the photo gallery, it sounds as though the 37-62 might have carried over into 1938 as the 38-62 with little change. http://www.nostalgiaair.org/Resources/211/M0013211.htm
You can no doubt get a 38-62 Philco service package from Chuck Schwark. http://www.philcorepairbench.com/schematics.htm These packages are well worth it.
John Honeycutt
The 37-62 schematic is the same.
Philco 91 Tuning Condenser
There are currently 10029 online users. [Complete List]
» 2 Member(s) | 10027 Guest(s)
