Identify This Cathedral
So...I've been home from work the past two days due to illness. No fun. While trying to take it easy, I've been watching the earliest episodes of Lassie (aka Jeff's Collie) via YouTube.
The cathedral radio in the Millers' parlor puzzles me as to its manufacturer:
[Image: http://www.philcoradio.com/images/phorum..._cath1.jpg]
Close-up of same radio:
[Image: http://www.philcoradio.com/images/phorum...cath1a.jpg]
Another view:
[Image: http://www.philcoradio.com/images/phorum..._cath2.jpg]
A closer look:
[Image: http://www.philcoradio.com/images/phorum...cath2a.jpg]
Three knobs, half-moon dial, round speaker opening with cut-outs, inset panel.
What say you, folks? Jackson-Bell, maybe? Any ideas of a model number?
I think we may have a winner:
http://www.radioatticarchives.com/radio.htm?radio=5419
Spot on, I'd say.
"Give the Little Lady her Cupie Doll..."
It looks like a Jackson Bell judging by the grille.
You guys are good
The grill cutouts don't look quite the same, but I believe Brenda Ann has correctly identified the set. Icon_thumbup I think Jackson-Bell cathedrals usually have variations in their grill cutouts?
There are currently 5399 online users. [Complete List]
» 5 Member(s) | 5394 Guest(s)
AvatarAvatarAvatarAvatar
