LINK for Zenith Chassis ID
For those that do not have it:
http://www.oldradios.com/reference/zenith.htm
Thanks for posting this link. I didn't have this useful info and it is now bookmarked. Thanks again!
Craig R.
There are currently 7136 online users. [Complete List]
» 3 Member(s) | 7133 Guest(s)
