  • 1 Vote(s) - 5 Average
New to the Forum
Ya I appreciate the concern and I already got that out of the way. I was doing a 67 mustang restoration a few years back and found a dead family of varmints in the cowl area. Thought id never get the smell to go away but thank the lord for bleach and a pressure washer.
Yeah, bleach is the king of clean and sanitation, that is correct.
Philco 91 Tuning Condenser
There are currently 6899 online users. [Complete List]
» 2 Member(s) | 6897 Guest(s)
