better source for water-slide decals?
I'm at the point where I need to put the water-slide decals on my Philco 38-690. What is the better source for them?
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
I am only aware of one vendor selling the PHILCO High Fidelity decals - Radio Daze.
http://www.radiodaze.com/product/6052.aspx
As for the decals that go above the knobs, I've had better luck with the Radio Daze decals than the Antique Electronic Supply decals - the last time I used the AES decals that go around the knobs, they "blistered" when I sprayed the protective coating of lacquer on them. The Radio Daze decals have never done that.
There are currently 10445 online users. [Complete List]
» 2 Member(s) | 10443 Guest(s)
