41-285 added to the family
picked a really nice 41-285 yesterday for $30. Will need a new escutcheon which Old Time Replications has in stock. I have my eye on an RCA 811K but the escutcheon has shrunk and twisted over time and I have not found where anything is available.
Sweet radio, great buy! The cabinet looks to be in excellent condition.
Joe
Philco 91 Tuning Condenser
There are currently 9829 online users. [Complete List]
» 1 Member(s) | 9828 Guest(s)
