Lear 667pc
A friend is selling a Lear 667pc AM plus turntable. Cabinet is in excellent shape but I know it needs a recap. Anyone have any knowledge of these? He gave me first dibs and I'm vaguely familiar with lear
The only thing I know about it is that he (Mr Lear) named his daughter Shanda sp
Wasn't one of them daughters Cordelia or something?
http://www.radiomuseum.org/r/lear_667pc.html and http://www.nostalgiaair.org/PagesByModel...010230.pdf
