hey guys
working on a 38-62 nos http://www.nostalgiaair.org/PagesByMode ... 013211.pdf
I don't have a .006 can I use .068 or .1 ?
also a .25 can I safely drop to .22
thanks sam
Your link does not work Sam.
Sam
Have you noticed that the difference between 0.006 and 0.068 is an order of magnitude (11 times)?
And between 0.006 and 0.1 is 17 times?
You can't do that.
Now yes, you usually can safely replace .25 with .22. Provided they both are in the same units.
hmm here link
http://www.nostalgiaair.org/PagesByModel...013211.pdf
ok so I don't have a .006 closes to temp try would be a .0047
for #23 6f6 tube
thanks sam
How bout going up a little to a .01?
murf
Sam
The closet standard value to 0.006 is 0.0056. I assume it is in microfarads so it is same as 5.6nF or 5,600pF depending on the search tool.
Philco 91 Tuning Condenser
There are currently 10122 online users. [Complete List]
» 2 Member(s) | 10120 Guest(s)
