How long do you let a freshly recapped radio cook.
How long do you let a freshly recapped radio cook before you do a final alignment? The 37-690 my father has has been running for about 2 months and I think its finally stabilized. This radio sat for many years in unknown conditions. I would guess damp. I looks like its time to bend over and spend a day aligning this beast!
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Hi Bill
I let the sets I restore play for an hour or two before I begin alignment. Point well taken on sets that have obviously been in a damp environment.
Philco 91 Tuning Condenser
There are currently 10043 online users. [Complete List]
» 1 Member(s) | 10042 Guest(s)
