philco 51 chaissis
need a picture of the 51 chassis , have a 551 clock that uses this both filter capacitors missing when i acquired it all tube and speaker were missing want to be sure as possible before powering up all wiring leading to filters is not there also have question s about choke on this model
Hi
I am sorry but I do not have a Model 51 here to take photos for you. Anyone else?
What are your questions about chokes? Please feel free to elaborate...
Philco 91 Tuning Condenser
