Philco Flexible Resistor wattage rating
What is the wattage rating on the Philco flexible resistors?
http://www.philcorepairbench.com/flexrest.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
There are currently 4484 online users. [Complete List]
» 1 Member(s) | 4483 Guest(s)
