Philco Power Transformers 3752, 4446, 4938 ???
Need to find what Model Philco's used these Power Transformers
I found the voltage charts for them, but need to know what Models they were used in
3752
4446
4938
Thanks
Bob T
Hi Bob,
I may be able to cross-ref these in my parts catalogues.
Will get back to you - at work right now. Later this evening.
Chuck
Hello Chuck
I found that the 4446 camee out of a Philco 90 with 2 45 in PP
That is what I was hoping to find.
Looks like I have to have Heyborer make me one
2.5 v @ around 12-13 A
Thank you for checking
Great you found your info.
I had not checked. Still at work yet…
Chuck
Bob, what kind of radio is it for? I probably have one for you.
Philco 91 Tuning Condenser
There are currently 9922 online users. [Complete List]
» 1 Member(s) | 9921 Guest(s)
