dial lamp
Quick question- does anyone know what number bulb to use in a Philco 70 dial? Looking at the schematic it looks like a 2.5 volt, correct?
P/N 3463 = #41, 2.5V lamp:
http://www.philcorepairbench.com/lamps.htm
Carl
Northern Panhandle, WV
thanks!
Eico 232 VTVM Schematic
There are currently 9542 online users. [Complete List]
» 1 Member(s) | 9541 Guest(s)
