Phonograph not amplfied
I am working on a 1932 Philco 22L I have everything working correctly except for the phonograph. The Phonograph will play and comes through the speakers but is not amplified. the radio is working properly as it should and the sound is amplified. I may be over looking something but I would greatly appreciate some advice.
Welcome to the Phorum. Your problem is more than likely a weak phono pickup cartridge if you get low volume output from your speaker. Not familiar with your set but does it have a plug in the back that the phono plugs into? If so, unplug the phono, turn the radio on and set to phono. With the volume set to the middle, touch a small metal tool into the center of the connector on the radio. Touch it briefly with your finger. If you get a loud hum, it's no doubt a weak cartridge that needs replacement/repair.
Jerry
Rhino
It is amplified otherwise you would not hear anything at all. Not enough amplification, this is it. Otherwise the sound you'd hear would be from the needle and nothing from the speaker.
Start from checking Volume reg 28, cap 32, cap 61and the switch - radio-phono.
Last tube before the 42, the 44.
Have you done the full recap? What else?
As for the pickup, it being electromagnetic and not piezo, I do not know ho often those go bad.
There are articles on how to check them, I never did that.
But before I blame the pickup, I would check the surroundings.
Assuming this is the one that had been for sale in Simpsonville? (that thread and CL ad has since expired.) I know the previous owner did not do any electrical restoration before using, but I thought he said the phonograph was working. Did anything happen in the interim that caused it to stop?
If you haven't already, replace all the paper and electrolytic capacitors.
My vote is for the cartridge. Had this before on a VM.
Tim
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM
Gloritone 27 Radio
Hello John, Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
There are currently 2479 online users. [Complete List]
» 3 Member(s) | 2476 Guest(s)
