Model 620 Electrolytic bypass
Newbie question. Restoring a model 620; part 52, 16 MFD electrolytic is being bypassed with new 16uf cap, I see where the components attach to the positive side of the cap but is there anywhere in particular where I should connect the negative side of the new cap, is the chase frame OK or should I use a specific ground point. Please advise, your help is greatly appreciated.
God Bless,
Dave
Hi David, Chassis frame is fine. Richard
Richard, thank you my freind, I appreciate it, kudos to you. Icon_biggrin
God bless,
Dave
David B, hi. You used the word "by-pass" and I got the feeling you may be placing the new cap across the old one. You can't do that as the old cap will still be in the curcuit. You have to remove all components attached to pos on old cap to a new attachment point (small terminal strip) with pos of new cap and other end of cap to chassis. PL
The filter caps do NOT go to ground. They go from B+ to the top of the large (usually overheated looking) rectifier B- resistors (#70 on schematic). Download your schematic and parts locator from NostalgiaAir.com
Sometimes it helps the radio by connecting an extra 10uuf from B+ to ground, but first the raw filter caps, the ones connected directly to the cathode of the 80, must be replaced.
As mentioned in the other post, you MUST disconnect at least one side of each of the old filter caps. Most restorers do the one-lead disconnect so that the original cap can be left in place for appearances. Leaving both sides connected leads to disaster- and lots of hum.
Pete AI2V
Dave AI2V is correct, the negs go to B- not chassis ground. Usually the clue is that the cap can is isolated from the chassis either by a non-metallic mounting wafer (twist on cans) or a cardboad or paper insulating tube around the can (clamp type). Manufacturers would not go through the added expense of isolating the cap only to wire it back to chassis. PL
There are currently 10491 online users. [Complete List]
» 2 Member(s) | 10489 Guest(s)
