Strange problem with 48-482
This is a weird one. I restored this 48-482 about a year ago and it has been playing daily in my shop. Lately I noticed that when tuning on AM, when I go under 780KHz, I get the scratchy noise (it actually cuts out) like a problem in the tuning cap. I get the same issue when tuning short wave. The weird part is that I get no problem on FM. I have done everything possible to clean it. I've examined every plate and don't see any rubbing.
Any ideas?
Eric
The Villages, FL
The highest likelihood is still rubbing plates in the cap gang. Or a dirty contact at the little clip(s) that maintain contact with the rotor shaft. The FM is probably a different section of plates and wouldn't be affected.
Thanks exray, I'll keep looking.
Eric
The Villages, FL
There are currently 8791 online users. [Complete List]
» 3 Member(s) | 8788 Guest(s)
