decal for 650 console
Am finishing up a Philco 650 console. Need to know where to put the Philco decal on the front of the cabinet. Have seen it two different places online. One right at the top of the cabinet and I found a couple that show it just below the dial. Which is correct? Thanks
Assuming it is a 650X...
http://www.philcoradio.com/gallery/1936a.htm#ak
It should be placed at the top of the front panel, near the top edge.
The proper decal to use is DCL-PH8 from Radio Daze.
http://www.radiodaze.com/product/6049.aspx
There are currently 8703 online users. [Complete List]
» 3 Member(s) | 8700 Guest(s)
