New member with a Philco 41-608
Any tips or info on BOL lamp, Photovoltaic cell replacement, or indicators bulbs for the HR-1 record cutter option would be much appreciated.  Or just direct me to old string of relevant posts.
Rick
Here's a link with some info.
http://philcoradio.com/phorum/showthread.php?tid=9754
bulbs are expensive right now    duh gave few away too Icon_cry
ebay
https://www.ebay.com/sch/i.html?_from=R4...pell_check
manuals will be up loaded  stay tuned  Icon_thumbup
Sam
Ur shopping at the wrong store! I'm surprise!
https://www.bulbtown.com/B9A_NE_48_NEON_..._p/b9a.htm
terry
thanks for heads up on it
never heard of them
4.00 each  with 6.00 ship    pretty good
sam
Thanks for the info.
Rick
The speaker table error?
Philco 70 antenna lead
There are currently 5901 online users. [Complete List]
» 1 Member(s) | 5900 Guest(s)
