02-08-2008, 01:14 PM
Looks like my osc coil in my Philco 41-250 has the green corrosion.
Any hints on rewinding it? Guage of wire, etc?
Thanks
Thanks
rewinding osc coil
Any hints on rewinding it? Guage of wire, etc? Thanks
02-28-2008, 06:44 PM
If enough of the coil has survived the corrosion, then
use a pin or needle to count the turns. Place the point of the needle on the former, and using very gentle pressure, slide it along the coil, counting the "bumps". Trying to unwind the coil and count that way is doomed to fail. After you have the number of turns, make a careful drawing of the coil, including the number of turns, direction of winding, length of the coils, and distances between the sections, if any. Then carefully unwind the wire, and try to compute a diameter of the wire. The exact diameter is not terribly important. Anyway, from the length of the coil, and the number of turns, you can get a diameter for the wire. Try to get something reasonably close in diameter, and rewind. Good luck
« Next Oldest | Next Newest »
Users browsing this thread: |
