Any Philco Radiobar Owners have an original Funnel?
I just picked up a full set glassware, and included was a funnel, the owner was the original owners son, and he said there were 2 of them in the family, and that everything was original? If anyone has a funnel from the set could you please post a pic so I can compare, Fingers crossed !
Thanks
Rock
There are currently 4000 online users. [Complete List]
» 1 Member(s) | 3999 Guest(s)
