Philco 84B
Hi,
Philco radio 84B, have a "big" speaker...who knows what is its diameter?
http://www.tuberadioland.com/philco84B-early.html
Regards,
Carlos
Regards from Portugal,
Carlos
8 inches, type SB
http://www.philcoradio.com/gallery/1934.htm#o
Hi Ron,
Many thanks.
Regards,
Carlos
Carlos
There are currently 7014 online users. [Complete List]
» 2 Member(s) | 7012 Guest(s)
