16B code 121 tombstone finish
As I tried to clean the side of the cabinet (just testing) with an alcohol,the finish started melting.The set is from 1933-34, I don't think they were using shellac that late (or did they?), yet I believe the finish is original (one can always tell otherwise). Even if it was not, who in the right mind would use shellac after stripping the lacquer? Any ideas?
Was it melting down to the wood? Just thinking it might be years of buildup that was melting instead?
Philco used lacquer on all of their wood cabinets.
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3840 online users. [Complete List]
» 2 Member(s) | 3838 Guest(s)
