Grill time! Making a replacement grill mold NEW PICS
#61
Nope, no issues. The plastic paint is perfect. You may be seeing lines from the actual plastic. They are not perfectly smoothe and I did not sand the few with the lines. I may do it as I sell them
Kirk
Saw them on eBay yesterday.
When you make your first million, we'll have a beer (we'll buy it at a place where there is no mold Icon_lol )
#63
I don't need one but they look so cool.....nice work.
There are currently 9484 online users. [Complete List]
» 1 Member(s) | 9483 Guest(s)
