Philco 610 chevron match
For my Philco 610F (the console version), is this the one I'm looking for? or is there a better match out there?
http://www.ebay.com/itm/Antique-Radio-Gr...280804819c
Charlie in San Antonio
Yup, that's the one...
Thanks, Ron.
There are currently 10548 online users. [Complete List]
» 2 Member(s) | 10546 Guest(s)
