116X alignment tools
The 116 x chassis has nuts that have to be adjusted during alignment, where can I find a plastic tool for this procedure or what do you use to do this. Metal sockets drive the radio crazy.
hi ron
do a phorum search on tool
sam
Ronin
Many of us made one from a plastic ballpen, by heating it up and morfing it around a proper size nut or standoff.
(11-16-2014, 06:15 PM)morzh Wrote:  Ronin
Great idea. I've ran into this same problem before.
The ballpoint pen trick worked like a charm, you guys are the best , the 116x is working like a champ.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 4259 online users. [Complete List]
» 1 Member(s) | 4258 Guest(s)
