Philco 660 Decals
Hi, I'm new to this site and was wondering if anyone can tell me where to find cabinet decals? I'm restoring a 1935 Philco model 660 radio and need the gold lettered "PHILCO" decal that goes under the tuner dial. Any help would be appreciated.  Icon_biggrin
Jerry
Hi and welcome!
I moved your post here since it is not dealing with a Philco TV set - it will get more exposure here.
You need the DCL-PH8 decal from Radio Daze:
http://www.radiodaze.com/product/6049.aspx
This is the proper decal for 1932-1936 Philco sets; it is also used on some early 1937 models also.
Edit: By the way, the 660 is a 1936 model.
There are currently 10213 online users. [Complete List]
» 1 Member(s) | 10212 Guest(s)
