help with Philco ID
All, I'm getting ready to restore a Philco Radiobar and I need help with identifying the Philco model.
Here's are some pictures.
radio in cabinet
front
top
underside
unknown damaged part
The front of the chassis is stamped 36-76 but I don't believe that is a model number.  Also, can someone identify the part that appears to be damaged?
Keith
That is a Philco 610 chassis (1936 model year).
Thanks Ron, I can't find a 36-610 schematic on Nostalgia Aire but the tube lineup does match a 610 based on the Grillecloth.com radio database.  The 37-610 seems to have a different tube lineup.
I found it on Nostaligia aire listed under just 610.
thanks,
Keith
(01-25-2015, 09:13 PM)keith49vj3 Wrote:  Thanks Ron, I can't find a 36-610 schematic
That's because there is no such thing as a 36-610. It is a Model 610.
Philco did not start using the model year prefixes (i.e. 37-, 38-, etc.) until the 1937 model year.
I see you found it, good. Icon_thumbup
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 2207 online users. [Complete List]
» 2 Member(s) | 2205 Guest(s)
