A cone crack - what is the best quick repair?
Single layer of small strip(s) of tissue paper soaked in diluted Elmer's white glue (50:50) applied both sides, but just wide enough to bond the crack/tear without unduly stiffening a large area.  Also, take a cotton swap in warm water to "pre-wet" the tear edges (both sides) for a better bond the to the dry cone.
Chuck
I bought contact cement today, did three layers on each side...will see how it behave.
There is this great tutorial for speaker repair that someone posted but I cant remember the name........
Oh I know ... ME!  Icon_lol
That was before I knew about Syls tutorials.
http://philcoradio.com/phorum/showthread...l#pid64287
Kirk
There is a glue for replacing speaker surrounds that is just right. For a small tear, artist's rubber cement is fine, although the days of paste up artists has passed, good luck getting it a reasonable pricel
Kirk
The problem is.....I drink ESPRESSO!!!!
With beer?
Why am I even bothering to ask  Icon_lol
Wait, beer before espresso makes quite the messo
Espresso before beer you're in the clear!
Just made that timeless quote up..
think some one is still on happy pills
Exactly.
Happy pils. Which one is that, The Bud? (it is an unhappy pils for me, I prefer Czech)
I used service cement for years but the last couple years I have been using products made by Springfield speaker repair. A lot of guys that do Hi-Fi speaker repair use their CSA and rubber cements. I finally gave them a try and found that they work very well.
You prefer Czech's,
I prefer ca$h.
But I'll take a Czech no matter how much it's written for!  Icon_lolno
Kirk
Note to self:
Check for a check for Czech beer. Check!
   On any speaker repair that I have done ,I used'' Pliabond''  It is made by Goodyear and it never gets hard.
        I am not sure where you can get it .. I get mine at Home Hardwar.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
