Tambour doors. RCA
Does anyone have any idea where I can find knobs for the tambour door on a 1933 RCA R-28D? I boorrowed the pic from radiomuseum.org. I hope that's O.K.
Have you tried any of the folk listed in the resources section?
I've bought from David, Julie, Mark and Mike in the past.  David, Julie and Mike all have original knobs.
Failing that you may be able to find close facsimiles through the Lee Valley hardware catalog, they literally have thousands of bits and pieces of cabinet hardware available.
(01-16-2015, 09:32 PM)klondike98 Wrote:  Have you tried any of the folk listed in the resources section?
I haven't tried that yet, but I will. Thanks
(01-17-2015, 01:14 AM)Arran Wrote:  Failing that you may be able to find close facsimiles through the Lee Valley hardware catalog, they literally have thousands of bits and pieces of cabinet hardware available.
Thanks. I'll give them a shot if I can't find anything in resources.
Pat
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3481 online users. [Complete List]
» 1 Member(s) | 3480 Guest(s)
