Useful Reference Books Free !
I know this is not about restoring a specific Philco radio, but several of the references in the link below are directly related to Philco radios, while others are full of more general, useful information for the electronic restored I already posted this in Old Ron's Bar and Grill, but I imagine there are those who read this section but don't go there, so I am posting it here too.  http://www.tuberadio.it/docs.htm  Some of these are LARGE PDF files, so, sorry to those with slow internet.
Already posted here:
http://www.philcoradio.com/phorum/showth...?tid=11437
Please continue discussion there.
There are currently 9320 online users. [Complete List]
» 3 Member(s) | 9317 Guest(s)
