Philco 40-190 is working fine.
Philco 40-190 is working fine. I would like to thank Ron Ramirez, etch, and TonyJSenior for all of their helpful information.
Best Wishes
NV3G
Oscar Icon_biggrin
There are currently 10302 online users. [Complete List]
» 2 Member(s) | 10300 Guest(s)
