Philco 23x
 I own a model 23x , but yet to see any others other than 4 of them on the web, 1 was for sale in san fran but missing phono, other was at auction and the other was on a web site tuberadioland and radio museum. How many do you guys think may be left? It looks like tuberland and radiomuseum pictures are of same radio so that makes it 3 times ive seen any others.
I had to look that one up on the gallery page. Good looking console in my opinion. I know I have not came across one or it probably would be in my collection.
I have a 501x with the automatic record changer. Have not got to it yet. It will need alot of cabinet work.
There are currently 10372 online users. [Complete List]
» 3 Member(s) | 10369 Guest(s)
